My first go at building my own pc
bhilly82
23
Well after my mobo on my dell i531 died this weekend i deiced to have a go with a diy home build. I will be re using the dvd drive, the power supply(i replaced the oem one with a 750 watt black widdow i think from best buy), and the 2 2tb spinning drives. I will be using a New OCZ 180gb agility 2 for the boot drive and programs i need. What i will be mostly using this pc for is Photo shop and light video editing(just shorting them and splicing) and Flight Sim X. Here is this list i bought from newegg, i know i ordered the slower memory just ordered the 1333 version and will have to rma the other. So tell me what you guys think of this settup for my use. As you can see i wanted to keep the price under 750 which i did.
HIS H467QR1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Item #: N82E16814161315
VGA Standard Return Policy
$69.99
MSI 870S-G46 AM3 AMD 870 SATA 6Gb/s ATX AMD Motherboard
Item #: N82E16813130590
$79.99
G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory Model F3-8500CL7Q-16GBRL
Item #: N82E16820231309
Memory Standard Return Policy
$119.99
Arctic Silver 5 Thermal Compound - OEM
Item #: N82E16835100007
Consumable Item Refund Only Return Policy
$11.98
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Item #: N82E16832116986
Software Standard Return Policy
$99.99
AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz Socket AM3 125W Six-Core Desktop Processor HDT90ZFBGRBOX
Item #: N82E16819103849
CPU Replacement Only Return Policy
$179.99
RAIDMAX Tornado ATX-238B Black SECC ATX Mid Tower Computer Case
Item #: N82E16811156243
$34.99
ICY DOCK MB882SP-1S-2B 2.5" to 3.5" SSD & SATA Hard Drive Converter
Item #: N82E16817994083
$14.99
I'd suggest using the sticky for builds as it lists your budget, what you using it for and preferred places to buy components otherwise you won't get many posts. You should also include links to the parts you've selected as it makes it easier for people to see exactly what you've got. The build is okay but your videoacrd is pretty old and there are better choices out there.
why are you getting 16gb of RAM? you could get half that and not use all of it, saving you some cash towards a better videocard.
you could also change the processor to a Phenom II X4 955 Black Edition, they overclock well and are great for gaming.
I do manly alot of photoshop which is a memory pig so yes i need 16gb, would of gone to 32gb but thats crazy expensive. But my build failed today, the mobo is shot blue screens every time saying somthing about a hardware fault, this happened right after the auto updater for msi updated the bios. so i am going to send it back to newegg i am getting a gigsbyte ga-990xa-ud3 r mobo plus its a am3+ so when bulldozer comes out.
I sent back that original video card and picked up a pny gtx 550ti from best buy for only $50 bucks, had some reward zone points as well it was on sale.
when the system was running it was very snappy and did what i need very well. It could convert a 20mb raw image to a 20mp jpeg faster then i could snap my finger which compared to my old e7400 rig which took a close to 30sec with 8gb of memory.
I do need 16gb with photo shop i have only 250 mb of free memory. When your working with a 50 layer 7500x9000 layout you need alot of memory. As far as video card i have a gtx 550ti in it, which is more then i need as the only game i play is mfsx.
^ Still doesn't need 16GB. Course, it does depend on how much you edit. I run with 18 MP RAWs at 5184x3456 and edit with a bunch of layers and some times even do Panoramas that are crazy high resolution and LOLOLOLOL I'm doing that all on 4GB of DDR3 1333 ram.
When i am working in photoshop i have around 128mb of ram free when i am finishing the layout. I know most on here build gaming rigs and in thouse 4gb is perfect but i was in need for 16gb.
