hey guys this is my first liquid cooling build and i dont want to make a mistake
this is my setup
i7 4770k
asus maximus VI formula
amd radeon r9 290x
16 gb corsair vengence ram
seasonic 1000w platinum psu
nzxt phantom 630
my liquid cooling parts
Tygon 2475 Ultra 1/4" ID (3/8" OD) tubing
Alphacool NexXxoS triple 120mm rad
Alphacool NexXxoS dual 120mm rad
EK Supremacy Clean Nickel + Green Acrylic cpu water block
EK-FB KIT ASUS M6F - Acetal+Nickel
motherboard water block
Koolance VID-AR290X vga water block
i want to know how much compressed fittings i need and how thick radiator i can fit on top and front of the case and how much tubing i need and best pump Reservoir for my needs and best uv green coolant
also any suggestion for my build or any changes i should make
thanks in advance
this is my setup
i7 4770k
amd radeon r9 290x
nzxt phantom 630
thanks in advance
