hello guys
im about to buy my 1st mechanical keyboard , i read many reviews & decided to get MX-brown switches
now regarding the keyboard ,what do u think about these 2 :
-CM QFR-i (rapid-i)
-CM Trigger z
i'll be using it to play dota 2 /cs:go
hello guys
-CM QFR-i (rapid-i)
-CM Trigger z
I've used CM before ... and personally it isn't my favorite keyboard I have the SteelSeries Apex Keyboard ... it's the ultimate one in my personal preference .. if i remember correctly you can customise the colors to over 16million different colors and choose what sections have certain colors and not to mention all the programmable keys.
That is my personal perference ... it's a large sum to pay out
If you want something cheaper ... steelseries apex RAW keyboard ... it's basically the...
hello guys
-CM QFR-i (rapid-i)
-CM Trigger z
If you want something cheaper ... steelseries apex RAW keyboard ... it's basically the 'lite' version of it 😛
I've just had bad experience with CM peripherals D: e.g. i've had a gaming mouse from them that had a squeaky wheel and i had a mechanical keyboard where some of the keys went bust in a couple of months lol soo wasn't too happy xD ... this is a few years ago though
the steelseries apex was my first choice also until i saw its price 😛 ,i will check out the apex raw now
im looking for a backlit mechanical keyboard (doesn't matter single color /rgb)
thank u for ur reply
