My First PC Build: Advice and help please!!
moomooo
34
Hello. I'm going to build a gaming pc soon and I Really need your help and advices.
I want to play BF3, skyrim, nfs:the run and assassins screed 3 and gta V in the future. (on ultra settings)
I have up to $700 I can use for a pc build.
I already have an un used power supply at home : Corsair 750TX 750 watts : watts http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139021
Case I don't need to spend a lot I just want a high air flow case. I thought of this one maybe : Cooler Master haf 912. www.newegg.ca/Product/Product.aspx?Item=N82E16811119233 It's Huge and I have some space to do cable managment since the psu i have is non modular.
Dvd player : Don't need a bluray. A normal dvd that can makes the job will be fine.
Memory : G. Skill DDr3 2x4 gb http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231314
What do you think ?
Cpu: I'm looking for the Intel i5 core around ($250) www.newegg.ca/Product/Product.aspx?Item=N82E16819115072& Can't affrod i7
This one seems decent for it's price. Can someone Tell me what is the diffrence between i5 2500 and i5 2500k? I compared both on newegg site but there is just no diffrence but the prices are diffrent.
I also want to know is it better to have an i5 or amd fx cpu ? or a phenom would be better for price/quality
Cpu cooler: I heard that stock fan sucks so maybe I can buy one that can makes the job and not so much expensive.
Motherboard: idk
HDD 320 to 500 gb will make the job
GPU: I prefer Radeon but i'm open for any suggestion. I have a viewsonic monitor 19" at 1280 x 1024. Don't need a new one i'm fine with it.
OS: I already own a copy of win 7 64 bits.
I don't want to overclock and I don't think i need double gpu.
Since i am from Canada, pieces are a bit more expensive than in the usa plus i need to pay for shipping and for customs system
I'm open to any suggestion for all parts.
My goal is to save maximum money while having a decent pc.
Thanks a lot.
ildreth
8
you don't need 8gb of ram, 4gb is more than enough for gaming, and dont buy "fast" ram because it doesnt make difference in gaming whether you have 1333mhz ram or 2400mhz, difference is 0-1%, i would buy 4gb 1333mhz ram cheapest possible
core i5 2500/2500k is probably one of the best performance/price cpu, if you don't want to oveclock then buy cheaper 2500, 2500k have unlocked multiplier so it can be oveclocked
amd cpus suck at gaming, avoid
you said that you dont want to overclock so don't buy cpu cooler, intel cooler maybe isnt the best but if you dont want to overclock then its more than enough, core i5 2500 isnt producing much heat
Motherboard: idk
I'd recommend cheapest possible p67 motherboard unless you want sli or any other fancy features...
gtx560ti or gtx570 (probably too expensive)
moomooo
34
Thanks!!! didn't no that thing about ram. :O
But can anyone make me a list of all the pieces with prices and links please ?
Thanks in advance.
moomooo
34
How about this
Case: HAF 912 http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119233&Tpk=haf912
CPU: Intel i5 2500 http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115073
Mobo: Asrock Extreme3 Gen3 LGA 1155 Intel Z68 http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157271
Gpu: EVGA GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130625
Memory: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231277
HDD: amsung by Seagate Spinpoint 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5"
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822152181
DVD Burner: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204
g-unit1111
37,916
6
96,215
2,440
OP is in Canada - that won't be an option.
The above build looks good but I really hate the 550TI - switch that out and get the Radeon 7850 if your budget allows. If not then get a 6850 - it will be far better than the 550TI.
moomooo
34
How about this one ? http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102908
Do you think i can run bf3 on ultra setting at a good fps rate with a 19" 1280 x 1024 monitor ?
Maybe I should cut in the cpu and get a better gpu ?
g-unit1111
37,916
6
96,215
2,440
Especially if you don't plan to overclock that wouldn't be a bad idea - you could cut the CPU from the 2500K to the i5-2400 and then upgrade your GPU to a Radeon 7850 or GTX 560TI.
moomooo
34
Thanks!!!
Just making sure... I don't to overclock to run bf3 at ultra settings ? :p
Could you link to good mobo that works well with the i5 2400 :)
ltpenguin
68
You should look into a i5-2400 or a i3-2120 as they are good enough for gaming. You should put more into a gpu and I suggest a z68 motherboard since it has intel virtu which switches between the integrated graphics and the gpu. Get a 6870 or above incase you decide to upgrade your monitor they are around 150-200 bucks
Check out ncix they have cheaper shipping and price match new egg.ca if you are going to pay with pay pal :)
moomooo
34
isn't i3-2120 a dual core ? quad core should be better no ?
ltpenguin
68
Yes you are correct a quad is better then a dual but for gaming a dual would pull through these games fine although a quad core would be better.
Pm= price match they ask for a source url, price match is located at the bottom of the check out area :3
Mobo:
http://ncix.com/products/index.php?sku=63945
Mobo Pm:
Cpu:
http://ncix.com/products/index.php?sku=57964
Cpu Pm:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115074
Case
http://ncix.com/products/index.php?sku=55583
it's cheaper so no pm i believe it is the same as the original one you linked
Gpu (on sale):
http://ncix.com/products/index.php?sku=64310&promoid=1211
HDD
http://ncix.com/products/index.php?sku=58402
cheaper than newegg
RAM:
http://ncix.com/products/index.php?sku=44267
Ram pm:
Burner
http://ncix.com/products/index.php?sku=69650
no pm needed it is cheaper :3
feel free to compare totals and shipping on newegg and ncix :3 feel free to question any of my suggestions
This totals to around $750 with aprox shipping if you don't fancy that i suggest the i3-2120 as it will bring it down to $700 give or take 10 dollars
I will gladly make you another option upon request :)
moomooo
34
I'm gonna make an account soon on http://ncix.com/ but is that site canadian and are there shipping fee ?
Great build thanks very much for your time. Here's mine. Same as yours, Only thing I changed is the Memory.
And let's say that ncix is a canadian site. It means there would be no shipping fee ?
Memory : http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231427$29.99 Same as your suggestion but it's 4gb instead of 8gb. Do i really need 8gb to get a better performance ?
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115074 I'm gonna give a try on the i5-2400.
Mobo: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157271
case: haf 912 http://ncix.com/products/index.php?sku=55583
HDD: http://ncix.com/products/index.php?sku=58402
Burner: http://ncix.com/products/index.php?sku=69650
GPu: http://ncix.com/products/index.php?sku=64310&promoid=1211
Ok Forget it about free shipping for ncix site. there are shipping fees but it's still less expensive than newegg.
Example haf912 case on ncix is : $59.98 + $21.03 shipping fees + gst = $81.01 total
haf 912 case on newegg.ca : $64.99 + shipping fees 19.99 + gst $4.25 = $89.23 total
$8 saved :)
I wanted to know if i take the i3-2120 instead of the i5-2400. Do i keep the same mobo as suggested for i5-2400.
And also it's better if i go with i5-2400 to have more fps in bf3m right ?
ltpenguin
68
yea they both work in the motherboard. The i5-2400 will make slight changes to your fps but it will also provided faster load times, as well be better for multi-tasking i for one have lots of programs open while gaming (ex. skype, chrome with lots of tabs and my music)
Edit: Also if you are only getting 4gb get 2x2gb dual channel memory to take advantage of the board features :3
moomooo
34
Cool i'll go with i5-2400. hope with the gpu and that cpu I can run bf3 on ultra setting at good fps rate ^^
and 4gb of memory instead of 8gb would be fine right ? or i should go with 8gb ?
ltpenguin
68
i believe they are put in at the check out page
moomooo
34
I'd like to know if I use my HDD and my dvd from my actual pc and install them into my new pc instead of buying a new hdd and new burner, will it change the performance of my new pc ?
ltpenguin
68
it depends on if they use sata connections. Although i would still replace the hdd you can always sell your computer after cleaning it.
Similar threads
