Question My first PC Build List.Need advice and suggestions if any.
Feb 23, 2024
Hello everybody! I am going to be building my PC soon. Before I buy the parts, I just wanted to make sure to post it here to see if anything was wrong so here it is. I am going to be using this PC for desktop work and some occasional gaming. (Most likely Telltale Games). Maybe the Arkham Series too. Mostly looking forward to playing on 1080p. (Appreciate any advice or alternative suggestions) My budget is under $1000. I also need clarification on my power wattage to see if its good. Thanks!
On the Newegg PSU calculation site, it said 400-499 watts. I'm thinking 650 watts should be good enough.
CPU
Intel i5 Series- 12400F
Comes with a heatsink.
Not interested in overclocking
CHIP SOCKET: LGA 1700
Intel Core i5-12400F - Core i5 12th Gen Alder Lake 6-Core 2.5 GHz LGA 1700 65W Desktop Processor - BX8071512400F - Newegg.com
MOTHERBOARD
ASRock B760 Pro RS LGA 1700 DDR4 ATX motherboard - Newegg.com
ASRock B760 Pro RS
FORM FACTOR: ATX
RAM
DDR4
16GB 3200Mhz
TEAMGROUP T-Force Vulcan Z DDR4 DRAM 16GB Kit (2x8GB) 3200MHz Desktop Memory Module (PC4-25600) CL16 Ram (Gray) - TLZGD416G3200HC16FDC01 at Amazon.com
SSD
PCIE Express NVME4.0 M.2 SSD 1TB
Western Digital WD_BLACK SN770 M.2 2280 1TB PCIe Gen4 16GT/s, up to 4 Lanes Internal Solid State Drive (SSD) WDS100T3X0E - Newegg.com
GPU
Radeon RX 6650XT 8GB VRAM(277mm) (Would love other suggestions)
Amazon.com: XFX Speedster SWFT210 Radeon RX 6650XT CORE Gaming Graphics Card with 8GB GDDR6 HDMI 3xDP, AMD RDNA 2 RX-665X8DFDY : Electronics
FANS(3)(Not sure if this is enough)
Artic p12 Max**(120mm)**
POWER SUPPLY (150 mm)
Corsair 650 Watt Power Supply ( I think 650 watts is good enough) Not sure. Its Bronze certified
CORSAIR CX-M CX650M 650 W Power Supply - Newegg.com
Wi-Fi CARD (BOARD DOES NOT COME WITH WIFI) Says it has a key e slot to put it in
Amazon.com: 10Dbi Antenna Wi-Fi 6E AX210 Bluetooth 5.3 5374Mbps 2.4Ghz 5Ghz 6Ghz 802.11ax/ac M.2 2230 Key E Desktop Kit Wireless Adapter AX210NGW Windows 10/11 : Electronics
CASE
FRACTAL DESIGN ATX MID TOWER
Fractal Design Focus G Black ATX Mid Tower Computer Case - Newegg.com
PCPartPicker Part List
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor ($148.99 @ Amazon)
CPU Cooler: *Thermalright Assassin King SE 66.17 CFM CPU Cooler ($19.89 @ Amazon)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard ($159.99 @ Amazon)
Memory: *Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($56.97 @ Amazon)
Storage: *Lexar NM710 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($64.94 @ Amazon)
Video Card: *PowerColor Fighter Radeon RX 7600 XT 16 GB Video Card ($319.99 @ Newegg)
Case: *Fractal Design Focus G ATX Mid Tower Case ($46.98 @ Newegg)
Power Supply: *Thermaltake Toughpower GF1 (2024) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($79.99 @ Newegg)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan ($8.99 @ Amazon)
Total: $906.73
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-02-24 00:03 EST-0500
Reactions: Lucky_SLS
