My First pc build. Pls review
Potatosalad_1
Commendable
Oct 4, 2016
This is my first pc build, every part is from newegg. Think of any parts that I could swap to make it better.(try to keep the cost below CAD $700
Total cost of pc is CAD $685
EVGA GeForce GTX 950 02G-P4-2957-KR 2GB SSC GAMING, Silent Cooling Gaming Graphics Card
GIGABYTE GA-F2A88X-D3HP (rev. 1.0) FM2+ AMD A88X (Bolton D4) SATA 6Gb/s USB 3.1 USB 3.0 HDMI ATX AMD Motherboard
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
DEEPCOOL TESSERACT SW Mid Tower Computer Case with Side Window and 2 Blue LED Fans SGCC+PLASTIC+RUBBER COATING
Rosewill ARC-M650, ARC Series 650W Modular Power Supply, 80 PLUS Bronze Certified, Single +12V Rail, Intel 4th Gen CPU Ready, SLI & CrossFire Ready
AMD A10-7700K Kaveri Quad-Core 3.4 GHz Socket FM2+ 95W AD770KXBJABOX Desktop Processor AMD Radeon R7
This would be far better, than that AMD rig.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($144.99 @ Amazon Canada)
Motherboard: Asus H110M-A/M.2 Micro ATX LGA1151 Motherboard ($74.99 @ Newegg Canada)
Memory: G.Skill Aegis 16GB (2 x 8GB) DDR4-2133 Memory ($84.99 @ Newegg Canada)
Video Card: Zotac GeForce GTX 1060 3GB 3GB Mini Video Card ($261.32 @ Amazon Canada)
Case: Deepcool TESSERACT SW ATX Mid Tower Case ($49.99 @ Newegg Canada)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($75.35 @ DirectCanada)
Total: $691.63...
I don't believe it's a good choice to get AMD right now, especially the Ax series, as they come with integrated graphics, so you're paying more for nothing, as you gonna buy a GPU too. If you wanna stick with AMD, get a FX. ( But i believe, anyone will recommend getting Intel )
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($258.95 @ Vuugo)
Motherboard: MSI H110M Gaming Micro ATX LGA1151 Motherboard ($84.99 @ Amazon Canada)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory ($52.98 @ DirectCanada)
Video Card: MSI GeForce GTX 950 2GB Video Card ($169.99 @ Newegg Canada)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply ($89.99 @ Newegg Canada)
Total: $706.89
Generated by PCPartPicker 2016-10-04 11:13 EDT-0400
I believe this build is better than your current one, a little more expensive, but the difference you'll get from AMD to Intel is huge.
If you can squeeze out a little more bucks, get a GTX 1060, it's about $100 more, but the perfomance is 2x maybe 3x better.
Total: $691.63
Generated by PCPartPicker 2016-10-04 11:48 EDT-0400
