So as the title says this is the first pc i've built, so im a bit anxious ill buy something and then build day comes and its incompatible, doesn't fit etc. So i was hoping you all could provide me with some reassurance, suggestions, alternative parts, etc. If anything i've listed on here might be incompatible please explain how so i can look for a solution. If its just an outdated part or obsolete because another company makes a similar part for cheaper etc. then just post a link to it. I'm buying all my parts off Amazon as thats probably easiest because i'm relatively new to this.
Parts List -
Xigmatek Spirit M Black Steel/ABS Micro-ATX Mini Tower Computer Case
Corsair Builder Series CX 430 Watt ATX/EPS 80 PLUS certified Power Supply
MSI ATX DDR3 2133 Motherboard 970 GAMING
AMD FX-8320 FX-Series 8-Core Black Edition
WD Blue 1TB Desktop 3.5 Inch SATA 6Gb/s 7200rpm Internal Hard Drive
EVGA GeForce GTX 750Ti SC 2GB GDDR5 Graphics Card
Kingston HyperX FURY 8GB Kit (2x4GB) 1866MHz DDR3 CL10 DIMM
Asus 24x DVD-RW Serial-ATA Internal OEM Optical Drive DRW-24B1ST
ASUS Wi-Fi PCI Express Adapter (PCE-AC56)
I'm also going to buy and install Windows 8.1 (I know most people hate it but i dont really mind it that bad) and i have a 32 inch tv for my monitor and keyboard and mouse from my current pc.
Any opinions or suggestions are welcome. Thanks ahead of time
Parts List -
