[SOLVED] My first pc build with ryzen 7 2700x
Jul 28, 2020
I was hoping for some advice or suggestions on this pc build iv planned,
CPU: Ryzen 7 2700x
Motherboard: MSI AMD Ryzen B450
RAM: Corsair Vengeance, 2 x 8 Gb
GPU: Gigabyte RTX 2060
Storage: Samsung 860 1Tb SSD
PSU:
Case: GOLDEN FIELD N17 Mid tower
Cooling System:
Would this rig work well together? Or do you have any changes or suggestions you recommended for the setup?
Please let me know, I plan to use this pc for playing games like Apex Legends, Warzone, BO3 custom zombies and other FPS games,
also some light video editing.
I’m not one for ultra graphics just high and smooth running game play and I’m willing to upgrade parts and more money on the rig if it means it will be smoother and last longer.
CPU: Ryzen 7 2700x
PSU:
Cooling System:
If your main focus is...
Your PC will not turn on due to no power supply.
Just kidding, its a good combo of parts.
What is your budget. And what monitor are you using?
Where are you located? Is there a Microcenter nearby?
My budget is £1000-1500 and the monitor I’m using is a Benq
My budget is £1000-1500 and the monitor I use for my Xbox is a Benq 60hz but I planned to buy a need one for the pc.
I’m in Kent.
CPU: Ryzen 7 2700x
PSU:
Cooling System:
If your main focus is gaming you can go for the ryzen 5 3600 or ryzen 5 3600X they both perform better in games compared to the ryzen 2 2700X
