I want a PC that can run games with no problem and record/stream.
Here are the specs-
BLUETOOTH:None
CABLE:None
CAS:Cooler Master HAF-X w/ USB 3.0, EZ Swap HDD, Fan Control, 1x 230mm & 1x 200mm fans [+125]
CASUPGRADE:None
CC:None
CD:24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive [+17] (BLACK COLOR)
CD2:None
COOLANT:Standard Coolant
CPU:Intel® Core™ i7-5960X Extreme Edition Eight-Core 3.00GHz 20MB Intel Smart Cache LGA2011-V3 [+680]
CS_FAN😀efault case fans
DOCKINGSTATION:None
ENGRAVING:None
ENGRAVING_MSG:
FA_HDD:None
FAN😀eepCool GAMMAXX 400 CPU Air Cooler 4 Heatpipes 120MM [-7]
FLASHMEDIA:None
FREEBIE_CU:None
HD_M2PCIE:None
HDD:480GB Intel 535 Series SATA-III 6.0Gb/s SSD – 540MB/s Read & 490MB/s Write [+38] (Single Drive)
HDD2:None
HEADSET:None
HS_HANGER:None
IUSB:Built-in USB 2.0 Ports
KEYBOARD:Razer Blackwidow Chroma Mechanical Gaming Keyboard [+163]
MEMORY:16GB (4GBx4) DDR4/2666MHz Quad Channel Memory [+59] (GSKILL Ripjaws 4 [+54])
MONITOR:* 24" Widescreen 1920x1080 ASUS VS247H-P 1080P (23.6" Viewable) 2ms LED Backlight, DVI, HDMI Input [+169] (Single Monitor)
MOPAD:None
MOTHERBOARD:GIGABYTE X99-UD4 ATX w/ Intel GbE LAN, 4x Gen3 PCIe x16, 3 PCIe x1, 1x M.2, 10x SATA 6Gb/s
MOUSE:None
NETWORK:Onboard Gigabit LAN Network
NOISEREDUCE1:Sound Absorbing Foam on Side, Top And Bottom panels [+29]
OS:Windows 8.1 (Free upgrade to Windows 10 when it is released)
OVERCLOCK:No Overclocking
POWERSUPPLY:1,200 Watts - Cooler Master Silent Pro Gold 80 PLUS Gold, Semi-Modular Power Supply [+100]
SLI_BRIDGE:None
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS:None
TEMP:None
TUNING:None
TVRC:None
USBFLASH:None
USBHD:None
USBX:None
VIDEO:NVIDIA GeForce GTX 980 Ti 6GB GDDR5 PCIe 3.0 x16 Video Card [-421] (Single Card)
WNC:None
WTV:None
Please leave suggestions on what and how to make it better thank you.
Here are the specs-
BLUETOOTH:None
CABLE:None
CASUPGRADE:None
CC:None
CD2:None
DOCKINGSTATION:None
ENGRAVING:None
ENGRAVING_MSG:
FA_HDD:None
FLASHMEDIA:None
FREEBIE_CU:None
HD_M2PCIE:None
HDD2:None
HEADSET:None
HS_HANGER:None
MOPAD:None
MOUSE:None
SLI_BRIDGE:None
SPEAKERS:None
TEMP:None
TUNING:None
TVRC:None
USBFLASH:None
USBHD:None
USBX:None
WNC:None
WTV:None
