Hi guys I'm planning to build my first PC and these are the components that I will use :
- GPU : Msi Radeon RX480 4GB ( because the 8 GB version is like 300 bucks here in Holland )
- CPU : FX-8350 ( maybe the Wraith edition )
- MOBO : Asrock 970A-G/3.1 / Asrock 970 Pro3 R2.0 ( not sure about that )
- SSD : Kingston Technology SSDNow UV400 - 120GB
- Case : Corsair Carbide 100R - Window Edition
- RAM : HyperX Fury - DDR3 1866Mhz CL10 Black - 8GB
- PSU : Not sure about that but i think this one : Cooler Master GM Series -550W
Makes a total of around 750 euro without OS
I already did some research and these parts should be compatible ( MOBO with BIOS update ) and there should be no big bottlenecking between CPU and the CPU.
If you guys got any recommendations it would be really nice but if its possible I want to stick in the 750-ish range.
- Superpeanut
- Superpeanut
