My first pc build
Nov 25, 2016
21
I made my first pc build that i will buy soon and the spec of that pc are :
- i5 6500 or i5 6600(20euro more does worth ?)
- gigabyte g1 gtx 1070
- asrock h170 pro4
- 2x4gb ddr4 2400 savage will buy in butter 2x8 or 2x4
- seasonic x 650
- master cooler masterbox5
- maybe evo 212 its cheap and look cool in case with windows
If you have something to add or change and why say me.
I want to play with this pc in next 2-3 year on near max settings and then on high and to be able to play 5 year in 60+ fps with medium settings.I will play witcher 3 fallout assassins creed
hitman lol and other new game i will play in singlerplayer only lol and little mc in multiplayer.
So first off, if you are just gaming, the i5-6400 is ok. You hardly notice anything. Especially in gaming. Also you will not need a CPU cooler because you can use the one that came with it. Plus you can downgrade to the B150 chipset to save some more money.
lol i nearly forgot the non-k cpu had stock coolers thx
i5 6400 have 500mhz clock speed and only 10 eurp less so i go for i5 6500 for sure i want to take some better mobo like h170 so later i can take another 1070 or to replace with 1080 and to take some i7 non k .
Will be difference betwen 8 and 16 ram if i dont fill this 8 ram in gaming ?
