Build Advice My first PC build
Jun 10, 2025
5
Hi,
I'm new to pc building and would like to build my first gaming pc that'll be somewhat future proof. I'm building for 1440p with about a £2000 budget. I'm just posting this to see if I can get any advice on if I selected the right parts and if they support each other or if I've gone wrong somewhere. The components I'm looking at so far are as shown below and the link for the list is here: https://uk.pcpartpicker.com/user/Abu-_-AS/saved/#view=zFhfhM
CPUAMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor
CPU CoolerThermalright Aqua Elite V3 66.17 CFM Liquid CPU Cooler
MotherboardGigabyte B850 AORUS ELITE WIFI7 ICE ATX AM5 Motherboard
MemoryCrucial Pro Overclocking 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory
StorageSilicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video CardASRock Steel Legend Radeon RX 9070 XT 16 GB Video Card
CaseMontech AIR 903 BASE ATX Mid Tower Case
MonitorMSI G272QPF E2 27.0" 2560 x 1440 180 Hz Monitor
PSUCorsair RM850e (2025) 850 W Fully Modular ATX Power Supply
Bottom FansThermalright TL-C12W-S V3 X3 66.17 CFM 120 mm Fans 3-Pack
I'd appreciate any feedback or help. Thanks!
Hi there, I see we're going for a similar build (9800X3D/9070XT). Might I suggest RAM with lower CL? CL30 is better than CL36 and gets you slightly better performance.
As for the monitor: What types of games are you looking to play? In 1440p ultra, a 9070XT will get you 80 FPS (ray tracing) to 100 FPS (no ray tracing).
It might be good enough to have a 120 Hz that will have an ever so slightly lower power draw and might be cheaper.
PSU: Long term, it's worth it in terms of money to go buy a platinum/titanium certified PSU. To give you an idea, in terms of electricity price and at 23p/kWh, in 2 years you have gotten back your extra investment in the PSU price between gold/platinum or titanium. In 4 years, you saved the full price of the PSU. 8 years, and you saved enough for your next mid range mobo. Add a bit of a tweak in undervolting
If you have a titanium, it's more than that because titanium is rated 90% efficient at 10% power draw (which no other type is rated for, meaning you probably save a lot more electricity at low loads/idle). I can't give you an estimate of the savings as there are no efficiency ratings under 10% load for the other certifications, only that it's better.
Reactions: 2009-_-ryhan
Thanks for the tips that'll definitely help a lot and I appreciate it. In terms of the sorta games I'd like to play are mostly single player, Clair Obsucr, GoW Ragnarok, TES 6 if it ever comes out 😆. I might use ray tracing to see what it's like. I've got a couple of questions though like what and why does CL matter. How come the FPS would reach 100 and would you have any examples of PSUs to recommend?
CL or CAS latency: CAS (Column Address Strobe or Signal) latency is how many “clock cycles” it takes for the module to access a specific set of data in one of its columns to make it available to the output. As rule of thumb, the faster your RAM is, the higher the CL (there are exceptions, expensive ones)... But within the same speed, you have RAMs that access their memory faster.
Between a CL36 and a CL30, you're getting your info out of the RAM 16% faster. Price difference is generally minimal (unless you try to get some CL26 6000MT/s which will be 50% more expensive). There's some nice Corsair Vengeance 6000MT/s with CL30 available for cheapish (less than £100 for 32GB). For £5 more, you can even find some CL28.
PSU wise, I've managed to find a be quiet dark power 13 850W Titanium for £109.95 at AWD-IT but it often gets back to £199. It's a matter of keeping an eye out on pcparts.uk and nabbing it when it's there. I've seen it a 112 or less 3 times over the past 6 months, so it does happen.
Thanks a bunch mate, that's really helped me a lot.
PCPartPicker Part List
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor (£413.00 @ Amazon UK)
CPU Cooler: ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler (£29.99 @ Amazon UK)
Motherboard: Asus ROG STRIX B650-A GAMING WIFI ATX AM5 Motherboard (£151.94 @ CCL Computers)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory (£99.58 @ Amazon UK)
Storage: Crucial T500 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£120.46 @ Amazon UK)
Video Card: ASRock Taichi OC Radeon RX 9070 XT 16 GB Video Card (£653.94 @ CCL Computers)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case (£85.00 @ Computer Orbit)
Power Supply: be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£105.00 @ Computer Orbit)
Total: £1658.91
Generated by PCPartPicker 2025-06-10 14:33 BST+0100
Here is my proposal with a few key changes like a nice OLED screen:
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor (£349.50 @ Amazon UK)
CPU Cooler: Thermalright Royal Pretor 130 BLACK 81.88 CFM CPU Cooler (£42.00 @ Computer Orbit)
Motherboard: Gigabyte X870 EAGLE WIFI7 ATX AM5 Motherboard (£191.75 @ NeoComputers)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£101.38 @ Amazon UK)
Storage: SK Hynix Platinum P41 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£119.99 @ Amazon UK)
Video Card: PowerColor Hellhound OC Radeon RX 9070 XT 16 GB Video Card (£649.99 @ Overclockers.co.uk)
Case: Fractal Design Focus 2 RGB ATX Mid Tower Case (£62.49 @ Ebuyer)
Power Supply: Thermaltake Toughpower PF3 750 W 80+ Platinum Certified Fully Modular ATX Power Supply (£99.98 @ Scan.co.uk)
Monitor: AOC Agon PRO AG276QZD2 26.7" 2560 x 1440 240 Hz Monitor (£447.00 @ Box Limited)
Total: £2064.08
Generated by PCPartPicker 2025-06-10 16:20 BST+0100
Hi,
You want DDR5-6000 CL30 seeing how games benefit from low latency RAM. Here's a few cost cutters ... no extra case fans required.
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor (£349.50 @ Amazon UK)
CPU Cooler: *ARCTIC Liquid Freezer III Pro A-RGB 360 77 CFM Liquid CPU Cooler (£86.49 @ Amazon UK)
Motherboard: *Gigabyte B650E AORUS ELITE X AX ICE ATX AM5 Motherboard (£198.99 @ Amazon UK)
Memory: *TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£97.66 @ NeoComputers)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£90.99 @ Amazon UK)
Video Card: *ASRock Steel Legend Radeon RX 9070 XT 16 GB Video Card (£659.99 @ Overclockers.co.uk)
Case: *Montech AIR 903 MAX ATX Mid Tower Case (£59.99 @ Overclockers.co.uk)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£124.95 @ Amazon UK)
Monitor: *MSI G272QPF E2 27.0" 2560 x 1440 180 Hz Monitor (£158.97 @ Amazon UK)
Total: £1827.53
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2025-06-10 20:36 BST+0100
A better look at those components.
https://www.gigabyte.com/Motherboard/B650E-AORUS-ELITE-X-AX-ICE-rev-12
https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5-WHITE
https://www.montechpc.com/air-903-max
https://www.techpowerup.com/review/montech-air-903-max/
https://www.tomshardware.com/pc-components/pc-cases/montech-air-903-max-case-review
View: https://www.youtube.com/watch?v=1RbcQeSO-1U
Total: £1827.53
Curious about if you could explain why you chose the 7 7800X3D and your other choices?
Reactions: Why_Me
Agreed with Why_Me, you'd be a bit more future proof if you have the budget for it. It is, after all, the best gaming CPU on the market at the moment. The 7800X3D is a close 3rd.
Spend less now, have more later. The 7800X3D will get you the vast majority of performance and save you some. If we get a 10800X3D, rumors are that it will be a single CCD 12 core and with a decent node jump. I feel that would be a much better long term investment than a 9800X3D, but it depends on what you want to do.
