My first plan to build a PC
supawichza400
Commendable
Sep 30, 2016
I am planning to build my very first gaming PC and I would like your advice if my chosen hardware is going to work or not and any improvement that I can make with this hardware. to play game like GTA 5, COUNTER STRIKE, LEAGUE OF LEGEND
Also my Budget for this PC is £1,000
this is the list of my chosen
CASE:Cooler Master RC-K380-KWN1 K380 "Mid Tower, ATX, Large Windowed Side Panel, Mesh Front Panel, USB 3.0, Red LED fan"
£38.99
WIRELESS CARD:TP-LINK Archer T6E AC1300 Dual Band Wireless PCI Express Adapter with Two Antennas, Selectable Dual Band Speeds 867/400 Mbps, Heat
£37.98
THERMAL PASTE:Arctic Cooling MX-4 4g Thermal Compound
£3.95
PROCESSOR COOLING:Cooler Master RR-212X-17PK-R1 Hyper 212X "CPU Air Cooler, 4 Continuous Direct Contact Heatpipes"£30.98
POWER SUPPLY:Corsair CP-9020103-UK CX Series CX650M ATX/EPS Semi-Modular 82 Plus Bronze 650 W Power Supply Unit
£62.64
MOTHERBOARD:Asus Z170 Pro Gaming Motherboard
£129.99
RAM:G-Skill 8GBXL Ripjaws X for Intel Sandybridge Platforms DDR3 PC12800 1600MHz 8GB Kit
HARD DISK:Seagate Desktop 3.5 inch 2TB 7200 RPM 64MB 6GB/S Internal SATA Drive
£60.90
VIDEO CARD:EVGA NVIDIA GeForce GTX 1060 Superclocked Gaming 6 GB GDDR5 Memory PCI Express 3 Graphics Card
£259.99
CPU:Intel Core I7-6700K Processor (4 GHz, 8 M Cache, LGA1151)
Thank you very much for all the reply
if there anything i need to add do not hesitate to post it
This would be much better for gaming
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (£209.72 @ Amazon UK)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler (£39.99 @ Ebuyer)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard (£119.99 @ Amazon UK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory (£75.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£42.99 @ Amazon UK)
Video Card: Palit GeForce GTX 1070 8GB JetStream Video Card (£379.98 @ Amazon UK)
Case: NZXT S340 (White) ATX Mid Tower Case (£63.87 @ CCL...
Looks fairly nice, I dunno if the fan will fit (check the case width and the fan is 160mm)
If I may ask though, why such an overpowered CPU? I mean it's not a bad thing to have but I would get an i5 6600k and swap for a 1070 or pocket it personally because I think you should get good frames in any of those three games with the 6600k anyways.
Case: NZXT S340 (White) ATX Mid Tower Case (£63.87 @ CCL Computers)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply (£53.09 @ CCL Computers)
Wireless Network Adapter: TP-Link TL-WDN4800 PCI-Express x1 802.11a/b/g/n Wi-Fi Adapter (£27.98 @ Novatech)
Total: £1013.60
Generated by PCPartPicker 2016-09-30 22:52 BST+0100
Your parts are fine though.
