Question My first (to be) Build review!
Sep 30, 2020
Hi guys!
In advance thank you so much for giving me a hand! I wouldnt say im a goof with pc hardware, but you never know..
My aim with the build is to have a clean White/Black, low RGB mid to high tier BEAST!
Im more about getting the better "bang for the buck" and "futureproofing".
Thats why i thought a Ryzen 7 or 9, so the CPU may last 5+ years including 1 or 2 GPU upgrades. As well as a gen4 SSD.
Furthermore im a big fan of good airflow and silence, hence the case and fans i chose as of now.
It should roughly max out at around € 2k, of course Im very happy with a cheaper build.
My plan (if its aprooved by someone with actual knowledge of the matter) is to get a cheaper GPU for now and I might upgrade once the 3000 series is wider available.
PCPartPicker Part List
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor (€407.99 @ Mindfactory)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler (€73.90 @ Amazon Deutschland)
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard (€169.63 @ Alza)
Memory: Corsair Dominator Platinum RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (€163.69 @ Amazon Deutschland)
Storage: Corsair MP600 Force Series Gen4 500 GB M.2-2280 NVME Solid State Drive (€105.90 @ Amazon Deutschland)
Storage: Corsair MP600 Force Series Gen4 1 TB M.2-2280 NVME Solid State Drive (€176.90 @ Amazon Deutschland)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive (€58.79 @ Mindfactory)
Video Card: Asus Radeon RX 5700 XT 8 GB TUF Gaming X3 OC Video Card (€361.00 @ Amazon Deutschland)
Case: Fractal Design Meshify S2 ATX Mid Tower Case (€135.99 @ Amazon Deutschland)
Power Supply: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (€116.69 @ Alternate)
Case Fan: be quiet! Silent Wings 3 50.5 CFM 120 mm Fan (€21.30 @ Aquatuning)
Total: €1834.38
Generated by PCPartPicker 2020-09-30 22:06 CEST+0200
I have no peripherals at all so far, thats secundary i guess! Also open for suggestions!
PS: Im kind of a BeQuiet fanboy :D
PPS: Keep in mind im from Austria ;)
At the top of your PCPP build list is a yellow bar. In that yellow bar, click the "BB" and it will give you a bunch of text to copy. Paste all that stuff here and it will show everything we need to see.
thank you, didnt know that was a thing! :)
Sep 30, 2020
I think it's generally good:
No need to waste money on dual MP600s. Just get the 1TB.
I was thinking to have the half gig MP600 mainly for my OS and the gig one for games I am currently playing
Would you recommend going for the RX 5700 XT for now, or would you advise trying to get a second hand 2070s/2080?
On the PCPP it sais something about the front panel USB 3.2 not being compatible with the motherboard.. is this any concern at all, or could you advise a equivalent (preferably white-ish) MOBO?
