My Fix For Corsair K70 Repeating Keystrokes
Xanthic
121
If you have a Corsair K70 RGB with Browns and have a problem with keystrokes repeating themselves, I found a fix that worked for me!
In the front of the keyboard, there is a switch that has "1, 2, 4, 8, BIOS". Make the switch go to BIOS and switch it back to whatever you had it on. It fixed itself within a day for me and I haven't had the problem since!
I'm responding to this thread to save it from deletion. This may be of help to those in the community with the same issue. I would like to ask you though, what your full system's specs and OS are? I would ofc suggest that folks make sure your motherboard BIOS is up to date and that chipset/USB drivers are all up to date.
i5 3570k, gtx 970, asus ph 77-vle
I'm not sure why you selected my post as the Best Solution, perhaps it was by accident? :)
When listing your full system's specs, list them as:
CPU:
Mobo:
Ram:
GPU:
SSD/HDD:
PSU:
OS:
This paints a better picture to those in the field and wondering what is wrong.
Yeah, i know you SHOULD list them like that, but I felt lazy. Didn't mean to press best answer, but it was a pretty good answer :)
But if you're wondering,
i5 3570k
Asus PH77V-LE
16GB Corsair Vengeance
Kingston 240GB SSD, 2TB Seagate Green, 2TB Western Digital Green
GTX 970
Antec 620W Bronze
Windows 10
