Question My friend has an problem with colors on his display.
Feb 26, 2019
91
Hello,my friend has an issue with his screen.Colors on his screen are looking like a "deep fried" meme and they are more vibrant.He needs help as quick as possible.Thanks!
RLarcosPES2
165
16
4,595
4
Check for GPU drivers. Also check if the monitor needs additional drivers.
Try right clicking on the desktop and go to display settings, then advanced display settings,display adapters properties for display the finally list all modes. If the desired resolution is shown then set it from there.
You should list your specs.
