Question my friends computer keep sunden restarting after upgrading parts
LTECl
53
HELP needed
Proc : intel i5-14600kf (NEW!!!)
Mobo : msi pro b760m-A wifi ddr4 (NEW!!!)
VGA : gigabyte rtx 4060 eagle OC (NEW!!!)
RAM : RAM DDR4 Corsair/GSkill 16GB (2x8) gb (NEW!!!)
Cooler : prime polar 240 T v2.0 liquid cooler (NEW!!!)
Storage : SSD Samsung Evo 860 250GB , hardisk 1 TB (OLD)
PSU : Corsair CX650M modular (OLD)
this is his spec
WIN 10 keep restarting with out BDOS like 5-10 mnt
note: even when in bios the pc keep restarting...
Have you tried testing the RAM first using a bootable Memtest USB drive?
I know older versions of Windows had issues with it's configuration if you change the motherboard, a fresh install of Windows would be required, because the chipset drivers wouldn't be compatible. But I'm not sure about Windows 10 or Windows 11.
Failure after a time smacks of a heat issue.
Check the cpu temperatures.
Look for possible aio failure or installation issue.
For example, is the aio pump connected to a pump header or set to run at 100% always?
You're last post didn't help, you just reposted the system specifications. Did you see our questions? Please let us know cpu temp, if you tested the RAM and if you've tried a fresh install of the OS.
this is the new upgrade PC...
it keep restarting even in bios... 5 mnt - 10 mnt the pc restart
Reposting or bumping threads is a good way to get threads closed.
Answering questions that are asked is a good way to get problems solved.
HELP needed
this is his spec
Unplug both disk..... boot to the bios and see if it makes a diff.
While sitting in the bios look around for a temp monitor.
i will tell my friend to test first... thanks for replied
thanks for replied... i will let my friend try this...
sry i post it in the other forum... moderator put my question from there to here...
i will try to answer as soon as possible... my time zone is different from USA sry for that
my friend said that the temperature is normal 40 celcius in idle
