M MaHuAkA Prominent Jul 4, 2017 5 0 510 Jun 3, 2018 #1 Hello. I buy GPU Gigabyte GV-N680OC-4GD, but when I put it on my PC it cry with the signal for no enough power. My motherboard is Asus P5K and I use 600 W power supply. Can you help me?
Solution kanewolf Jun 8, 2018 If your power supply has a single 6 pin PCIe power plug it is not sufficient to power that GPU. You will have to buy an appropriate power supply.
kanewolf Titan Moderator May 29, 2013 37,278 3,264 156,790 Jun 3, 2018 #2 Does your power supply have the correct PCIe power plugs (one 8 pin and one 6 pin) or are you using some kind of adapters? Upvote 0 Downvote
M MaHuAkA Prominent Jul 4, 2017 5 0 510 Jun 8, 2018 #3 My power supply have 6 pin cable and i use adapter 8 pin Upvote 0 Downvote
kanewolf Titan Moderator May 29, 2013 37,278 3,264 156,790 Jun 8, 2018 Solution #4 If your power supply has a single 6 pin PCIe power plug it is not sufficient to power that GPU. You will have to buy an appropriate power supply. Upvote 0 Downvote Solution
