Hello there,
So I built this PC almost 6 years ago, I replaced the motherboard and the CPU to newer gen, but my GPU stayed the same - GTX 970.
Today I was playing a video game and my computer suddenly shut off. I got confused and try to start it up but it wouldn't. I tried to smell for anything suspicious but couldn't. I guess it was stupid of me to re-plug the PSU again and again until the PC did start up, the fans started spinning, although only for a second or two, greeting me with the powerful odor of a burning component... I unplugged everything as fast as I could, checked every component and the smell was coming from the GPU/CPU area. I took out the GPU and I could definitely tell that the smell was coming from my GPU. I tried to smell where exactly the smoke was originating from and I found a capacitor that was kinda burnt..
I replaced my PSU, just to be sure, plugged everything in and started the PC with IG, everything booted up and seemed to be working. Although I did face a weird issue of laggy mouse?? And I got a BSOD soon after the mouse started lagging more and more. After the PC rebooted however, I didn't get any more BSOD, but the mouse was still laggy (skipping pixels, jumping), however after using it for a bit it fixed by itself which makes me paranoid at this point.
I'm really worried for my other components (mobo. CPU, RAM) and I want to make sure they're not damaged, how can I assure that? I stress tested my CPU with Prime95 for 1:30 h and everything seemed to be fine. Could the GPU being fried damage the other components and was it caused just by the age of the GPU or is the PSU the culprit here?
I would be really thankful for any kind of support regarding this, as I don't have the money to replace the nearly newly bought CPU, RAM and Mobo.. And I wonder if my old PSU can still be used.
Thanks in advance,
John
Thanks in advance,
John
