My Graphics Card fans aren't spinning
Luwazzi
155
Just finished putting together my first build and my graphics card fans aren't spinning, is this normal???? i have the NVIDIA gefore gtx 980ti, is there something i need to do in the software?? help please thankyou
It will only spin if its above a certain temperature. I forgot what the default was. But i set mine to spin after 40 degrees to 20%, 50 degrees 30% 60 degrees 40% and so on and it is lovely..MSI Afterbruner is best for this in the settings > fan> Enable User Define Software (check next to that) then set it up on the graph.
so the fans will only spin if they need to?
Try loading up a game because the graphics card might have a feature where the fans aren't spinning on idle.
cant test it right now, installing games to play atm
