My Graphics Card. Help
VuVou0
15
Ever since i plugged my graphics card my fps has dropped and since i ipdared my driver my fps also dropped... any help?
GeForce GTX 950
Driver 378.92
Intel(R) Core(TM) i3-6100 CPU (c) 3.70Ghz
Make sure you aren't plugging the video cable into the motherboard's output instead of the GPU's.
Also, check your new GeForce Experience software and see if it has "optimized" your games. Sometimes these optimizations are for better or worse when it comes to quality and performance.
I seen that with my 980ti with some drivers that took a hit . matter of fact I still use older 355.82 on it today
thing is just because its a new driver don't make it a better driver . don't hurt to try them and see but like me I end up back on 355.82 ?
find the ones that seem to work best for your card and use and stick with it or save it to fall back to
good luck
