My Graphics card won't display on my monitor
JasonC1995
So this morning I had a problem with my case USBs. It was giving me an error and I had to unplug my USB from my motherboard. Now I have an even bigger problem. When I plug my HDMI cable into my graphics card it won't display any picture. The cable is fine and it works with the motherboard display port, but I want it to work with my graphics card again.
My graphics card seems to be fine. The fans are running. My motherboard detects it so there should be no reason why the HDMI cable doesn't work.
Please help me. I need some advice.
Possible causes:
>HDMI port on GPU died - test different port
>GPU died - check it at another comp
>motherboard PCIe slot died - if your motherboard has more x16 slots, move GPU to next slot
JasonC1995
It probably is my HDMI port on that card. I tried a different GPU and it worked fine in the same motherboard port.
I was considering upgrading my card anyway, now with this going on it finally gave me a reason to buy a new one. Thanks for the answer, friend!
