Question My graphics card won't fit in properly. Any help?
Lutfij
Judging from the way the PCI expansion slot covers are mangled, you don't have the GPU in the right position or the case isn't aligned properly. You also put the ports side in first into the case before latching the rear end of the card to the PCIe slot.
