My GTX 1050 TI is asking for PCIe Power Cables
nsgssg
Commendable
Jan 7, 2017
4
Everything I read says I slot should be enough power and I don't need additional power cables, yet I get the following error when booting:
"PLEASE POWER DOWN AND CONNECT THE PCIe POWER CABLE(S) FOR THIS GRAPHICS CARD"
If it's a 6-pin connector even something like the VP-450 will work.
If you have sufficient power a 2xMOLEX-> 6-pin adapter might work
https://www.amazon.com/Link-Depot-Express-Adapter-Inches/dp/B000JWTIKC/ref=pd_lpo_147_lp_img_3?_encoding=UTF8&psc=1&refRID=M28PTQG1Z1E363VHSXTH
but you'd still need to buy a 6-pin PCIe cable so maybe just buy the power supply (may need to anyway)
VP-450: https://www.amazon.com/Antec-VP-450-Power-Supply/dp/B004IZN3K2
*So to be clear, there are 1050Ti's with no power connectors but if you have one you must use it.
I don't have PCIe power cables to plug in. I specifically got the th 1050 Ti because it said the power cables were optional. What else can I do?
The reference 1050Ti might not require a power connector but custom ones can have higher speeds and be designed for overclocking. If there is one then that means it needs it. If your PSU doesn't have the correct cables then it can't provide enough power.
TL;DR Get a better PSU.
I have a Gigabyte Geforce GTX 1050 Ti G1 Gaming 4G.
I'm not sure about the PSU. It's an HP model DPS-300AB-73 A. The manufacturer is: Delta Electronics Power (Dongguan) Co., Ltd.
We don't know his CPU unless I missed that, and since he needs an adapter AND a 6-pin PCIe cable he might as well spend $35 on a new power supply which we know will work.
A PSU that is barely adequate is probably also going to be loud, though sure a 300W can work if the system consumes roughly 150W or less (before graphics).
It's also useful to have a spare PSU to troubleshoot if things go wrong.
Thanks for all the feedback. I'll look to upgrade my PSU. I'll definitely go at least 450W, since I'm upgrading. But one last question, do the PCIe power cable(s) come with the new PSU, or can I just add cables to my existing PSU?
You can get adapter cables that convert e.g. a Molex or SATA (or pair of) to a 6-pin. We don't normally recommend them because people tend to use them to drive way too large cards on terrible PSUs, but a 1050Ti on a 300W Delta is OK.
A new PSU would come with the cables.
What do you mean by this? The adapter is the 6-pin cable.
