M MiloshDr Reputable Jul 12, 2016 108 1 4,685 Aug 5, 2016 #1 On my new computer. Is this normal levels? http://imgur.com/a/v4ZJq What do I do?
SkyNetRising Titan Jan 4, 2016 32,736 4,825 126,640 Aug 5, 2016 #2 MiloshDr : Is this normal levels? No it's not. Post screenshot from Resource Monitor disk section (order by total column descending). Upvote 0 Downvote
M MiloshDr Reputable Jul 12, 2016 108 1 4,685 Aug 5, 2016 #3 Imgur wont let me upload for now. My Disk is geting around 5% now to 40% spikes now after I went to the optimize driver software and optimized the OS (C. Does the software usually fix errors or could I still have errors? Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 32,736 4,825 126,640 Aug 5, 2016 #4 Upload your screenshot to tinypic.com If you're worried about drive health, then post screenshot from HDtune health section. Upvote 0 Downvote
M MiloshDr Reputable Jul 12, 2016 108 1 4,685 Aug 5, 2016 #5 The image finally uploaded. https://imgur.com/HFsMiFP here is it resources monitor Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 32,736 4,825 126,640 Aug 5, 2016 #6 As you can see, defragmenter is running. High disk usage during defragmentation process is normal. Wait until it finishes. You should configure defragmenter also, if you haven't done it. SSD drives should be excluded from defragmentation. Upvote 0 Downvote
M MiloshDr Reputable Jul 12, 2016 108 1 4,685 Aug 5, 2016 #7 Defragmenter wasn't running when I initially had the problem, could it be possible the software already fixed the issue? Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 32,736 4,825 126,640 Aug 5, 2016 #8 Ok, lets check drive health. Post HDtune screenshot, I asked for earlier. Did you know, you can just Alt+PrintScreen and paste into Paint to get a screenshot? Upvote 0 Downvote
M MiloshDr Reputable Jul 12, 2016 108 1 4,685 Aug 5, 2016 #9 https://imgur.com/6T4ugAC Here is the health. Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 32,736 4,825 126,640 Aug 5, 2016 Solution #10 Health of that drive is fine. I don't see any problem there. Upvote 0 Downvote Solution
