My pc was working nice.. suddenly it was not responding for nearly 20 min.. when i restarted my computer, i found my hard disk was not detected at the bios level... wat could be the problem? Any solution please..
Maybe the HDD just died.....
Something on the PCB blew up....
Change the power connector to another one from the same PSU, change the SATA cable and then change the port to which it is connected.... That's the max that can be done.
If none of those make it work, then you can be sure the HDD's gone....
