My hardrive stops working HELP
James Tran
After installing my new graphics card my hard drive suddenly stops working. And btw it's the only hard drive I have so what should do. I can't enter windows
Tried that but no
I assume that everything is plugged correctly. the sate and the power supply etc
verify be reconnecting them.and check to see that the
if you use the mole x to sata convertor.they did not got loose. mostly my molex -sate convertor is so lose if i touched the wire BAMM- hdd is disconnected.verify this and try again
I don't have a molex to sata converter
Still but I even tried pressing the connector against The hard drive.
Result: Doesn't work
