Question My HDD's Not stop spinning even though I set to stop at 1 min in Power options
Mar 22, 2024
5
Hi guys, My HDD's is not at all stopping the spin .. I have 2 hdd's both have same issue ..
I am on Windows 11 and 7950x3D + Asrock Taichi 670e Build
Please help
are you sure there isn't any disk activity?
Yes sir .. I confirm this from resource monitor .. I set timer for 1 min and observed resouce monitor for more than 2 mins nothing is accessing my hdds but they keep spinning
I strongly believe my new build is the reason behind this ..
I heard bios options can over ride os settings .. if this is true .. my new motherboard is having some option regarding this .. I dont know which one it could be 🙁
if you can suggest some I can try sir
If you're doing intensive activities, which Windows 11 might sometimes do in the background, or add to, your hard drive could be being accessed due to a need for swap memory, which is just taking a tiny chunk of your drive, and treating it like memory. It could also be that your computer has to pull new resources from its files, which would also access your hard drive frequently, given a big enough load. Perhaps you should look into your memory usage, and see if some of it's working incorrectly, or if you don't have enough for your standard use case.
