My HDMI cable that came with my monitor.
VerminsCulprit
58
Ok, everybody knows that HDMI makes ur screen faster. My HDMI cable has 1 end as a HDMI input and the other end is the wierd input that u screw in and its tan. I think it's called the DVI or DVII. So is that cable the highest graphics or do i need an HDMI to an HDMI. P.S. (My pc had a both outputs...DVI-DVII and HDMI)?
You monitor does have built in speakers...so if you use HDMI cable then you can play the sound through it. If you use DVI cable or DVI to HDMI cable, then you will not have sound play through the monitor. That is it...the visual quality will be the same.
Wait my monitor came with a DVI-HDMI cable now let me reask my question. Do I need to get a HDMI-HDMI cable for better performance?
Monitor: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB0QFjAA&url=http%3A%2F%2Fwww.asus.com%2FMonitors_Projectors%2FVN247HP%2F&ei=cfGsU4v9FMmRqAa2vYLQAQ&usg=AFQjCNGPi6vx5C2Hsi2jUEZQ-VEFSRpk0g&sig2=zrgNSCNu7Q_ZeffWkICFVQ&bvm=bv.69837884,d.b2k
