M mohammadjw555 Jun 29, 2018 19 0 10 Jul 12, 2018 #1 when i play a game that meets the system requirements it lags and its slow
Solution WildCard999 Jul 13, 2018 mohammadjw555 : WildCard999 : What game are you trying to play? the godfather 2 and mafia 2 Both games require a dedicated GPU, your iGPU is not enough to play those games smoothly. https://www.systemrequirementslab.com/cyri/requirements/the-godfather-ii/10856 https://www.systemrequirementslab.com/cyri/requirements/mafia-ii/10986
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Jul 12, 2018 #2 Most games require a dedicated GPU but post your specs including the monitor and the game your trying to play. Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,889 4,258 176,290 Jul 12, 2018 #3 If you only meet the base level system requirement, it will be lags and slow Upvote 0 Downvote
M mohammadjw555 Jun 29, 2018 19 0 10 Jul 12, 2018 #4 i open the system requirements lab and it says my graphics card is out of data but i updated it Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Jul 12, 2018 #5 mohammadjw555 : i open the system requirements lab and it says my graphics card is out of data but i updated it It may not mean that the drivers are out of date but the actual GPU/iGPU is. Can you list your specs and the game your trying to play? Upvote 0 Downvote
M mohammadjw555 Jun 29, 2018 19 0 10 Jul 13, 2018 #6 WildCard999 : mohammadjw555 : i open the system requirements lab and it says my graphics card is out of data but i updated it It may not mean that the drivers are out of date but the actual GPU/iGPU is. Can you list your specs and the game your trying to play? its a old old pc cpu is pentium 4 630 HT 3GB Ram ddr 2 igpu is nvidia geforce 7050 / nforce 610i windows 7 32 bit Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Jul 13, 2018 #7 What game are you trying to play? Upvote 0 Downvote
M mohammadjw555 Jun 29, 2018 19 0 10 Jul 13, 2018 #8 WildCard999 : What game are you trying to play? the godfather 2 and mafia 2 Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Jul 13, 2018 Solution #9 mohammadjw555 : WildCard999 : What game are you trying to play? the godfather 2 and mafia 2 Both games require a dedicated GPU, your iGPU is not enough to play those games smoothly. https://www.systemrequirementslab.com/cyri/requirements/the-godfather-ii/10856 https://www.systemrequirementslab.com/cyri/requirements/mafia-ii/10986 Upvote 0 Downvote Solution
M mohammadjw555 Jun 29, 2018 19 0 10 Jul 13, 2018 #10 WildCard999 : mohammadjw555 : WildCard999 : What game are you trying to play? the godfather 2 and mafia 2 Both games require a dedicated GPU, your iGPU is not enough to play those games smoothly. https://www.systemrequirementslab.com/cyri/requirements/the-godfather-ii/10856 https://www.systemrequirementslab.com/cyri/requirements/mafia-ii/10986 so i should get gpu Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,889 4,258 176,290 Jul 13, 2018 #11 from your other thread. a new pc probably better Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Jul 13, 2018 #12 Yes, fortunately you don't need anything expensive. A GPU such as the 5770 would be more then enough. Upvote 0 Downvote
