Hello, I have this SSD that has not worked in a while, and I'd like to use it on my laptop which I just fixed. The SSD stopped working after using it through a USB docking station a few years ago. I think I tried to install windows onto it and restoring the partitions and allocating the space.
My concern is that I somehow bricked the SSD while using it through USB - SATA docking, and somehow it was converted to only work through USB, since I was editing the partition and file system through USB to a PC.
I have opened the SSD to expose the circuit board, and everything looks fine exept one component on the board which I don't know what is. I will add a image and point to the component that looks damaged. Any help or advice would be greatly appreciated. Thanks!
Unedited image:
https://imgur.com/a/79W6PyL
Showing where the component is:
https://imgur.com/a/YqJoWOz
Anyone know what this component is, and if it might be causing the SSD to not work?
Unedited image:
