Question My Laptop has no power
Jul 16, 2022
87
6
35
I have an pretty old hp pavilion 15 cs model laptop...
It suddenly went off and has no sign of power whatsoever..
Please help 🙏
If you want any more details, I'm pleased to reply...
Ralston18
Original battery?
Original charger?
Has the laptop been plugged in and left to recharge? Are you sure that there is power at the charger's outlet?
Do you have any sources from which to borrow a known working battery and charger?
Ralston18
Unfortunately without some way to individually test battery and/or charger just as a matter of elimination - not much can be done.
I neglected to ask "how old" is "pretty old".
Any revision numbers or dates on the laptop?
Ralston18
4 years - overall, without knowing the laptop's history, my thought is that the battery has reached EOL (End of Life).
However, the charger may have failed. That may be testable.
You could try some restoration process. No guarantees and you must be very careful with any attempts.
For example (not recommending or endorsing):
https://h30434.www3.hp.com/t5/Notebook-Hardware-and-Upgrade-Questions/Dead-Battery-or/td-p/6382728
https://www.hp.com/us-en/shop/tech-takes/why-is-my-laptop-battery-not-charging
Jul 16, 2022
87
6
35
Ok thanks so much for your help ❤
Jul 16, 2022
87
6
35
I gave it to a local service center..
Without even opening the back he said it was a short circuit problem... But he also said that he might be wrong and offered to check once again, opening the backcase, and inform the problem clearly by tomorrow... I'll deliver the news by tomorrow night (or the next day, or the next... whenever he gives)
Stay tuned... ( if u want )....
Jul 16, 2022
87
6
35
Fair enough.
Do keep this thread up to date. Any sort of additional information may lead to further comments and suggestions.
Sad news... The laptop has com back........DEAD!
They said that the problem was with the IC Board and nothing could give life to my hopeless laptop... Trying to move on...
