My laptop wont turn on and wont charge. No light also
Khynjoan
I just use it while charging then I unplug the charger and shut it down. Hours later I tried charging it again but there is no light indicating that it is charging then I tried turning it on but it wont work. No light also.
Try removing the battery, then plug in the AC adapter. If the laptop turns on, the battery is the culprit. If that doesn't help, then you may have a problem with the motherboard at the AC in port.
