Hi!
I have a Sony Vaio vpcsb11fx, which I used for a year and a half with the default battery model number VGP-BPS24.
I unplugged my laptop and put it in Hibernate mode for the night. When I woke up and tried to turn on my laptop, I received an error message notifying of either incompatibility or the improper installation of the battery pack and my computer then entered Hibernate mode. Before it automatically Hibernated, I moused over the battery icon in the Task Bar and it said "Plugged in, not charging". This has never happened before.
Following the instructions of this manual, I opened up the laptop, removed the battery and reinserted it into the socket. I tried to turn the laptop back on while it was charging and nothing happened. All the while, if I ever plugged my laptop in, the battery indicator light on the bottom edge of the laptop would rapidly blink orange, which, according to the manual, means that there is a battery error.
Is there a way to fix this? Or will I have to buy a new battery?
Thank you in advance!
