my lenovo ideapad 360S will not turn on if unplugged . Even with full battery power.
Hi ,
Ive had my laptop for a year but I have never been able to turn it on unless it is plugged in.
when I do plug it in it shows I have full battery.
because of this issue I can only use it if there is a power socket close.
It continues to work once I unplug it . It just will not turn on
Sounds a lot like a bad battery (which can give a false reading) or the battery is not connecting correctly inside the laptop, which is causing it to not get enough power from it.
To be honest, I believe the first is more likely. I would look into replacing the battery.
