My Lenovo laptop suddenly swiched off can't power on what is the problem
du_riyad
While I was running lenevo laptop , the laptop switched off suddenly. I have tried several times after checking power connections to start the laptop but the power of laptop have not come ..... what is the problem ..how I can solve it
Try the following and see if it will turn on...
1. Unplug your charger cord.
2. Remove the battery.
3. Press and hold the "Power" button for 30 seconds.
4. Now plug back in the power/charger cord.
5. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop. You may also want to try charging it when the device is off, rather than on. If it works then, the cord is probably the issue.
Should that not be the problem, then check the battery to see if it needs replacing.
