Question My mg3620 printer is printing streaks and unaligned and nothing works
DualRevolvers
21
Lately, I've been having issues with my printer. It's been printing everything askew. I've tried literally everything that normal maintenance requires multiple times, including all the different cleaning options and aligning. Nothing has worked. I've yet to try new ink cartridges because I don't currently have any new ones and wouldn't want to waste any ink if I don't have to. Is there anything I can do or do I just buy a new printer? Pics provided.
View: https://imgur.com/a/BiChYXS
anytime that you get white, horizontal lines in the print is a very clear indication that some of the nozzles are clogged. This can be resolved simply by replacing the cartridge as these models have the actual printhead built into the cartridge. If it still has heaps of ink in it just remove the cartridge and sit it in a few ml of Windex for at least an hour. This will clear any dried ink that is blocking the very fine nozzles which spit the ink out. When re-installed the print quality should be perfect again.
