my microphone show that he's reciving sound from my speakers
bomboy 2121
94
for some reason my siberia v2 decided to do some weird stuffs
im trying to use it but it doesnt show me at all that im talking and when i play some music in the backgorund and it shows me that its reciving it from my speakers and from my microphone (i can still hear it loud and clear), im trying to talk to the microphone but it doesnt show anything and it only shows that its reciving voice when theres noise made by my computer
You may have missed a configuration setting or mis-configured an existing one.
Right click the speaker icon (lower right screen corner).
There are menu selections for Playback Devices and Recording Devices. Select Recording and look for your microphone. Select and right-click. Check all of properties and tabs. Lots of settings available so look carefully at what is set up.
Do the same for Playback Devices. Check the settings all the way through the various tabs and options.
Hopefully you will find a problem there and be able to reset accordingly.
i found out after i posted it that my microphone doesnt work on other computers/phones so the problem is with the headset...
still thanks for the try
