First of all, images of the stock backplate and cooler:
I bought a Silverstone Tundra TD03-SLIM but the screws are too thick. In my eye I really cannot appreciate a size difference between stock cooler screws and the AIO ones, so I think the difference in thickness should be a milimeter as much. How can I solve this situation? For more signs, I installed a Corsair H75 before and it fit perfectly in the stock backplate, but the radiator and fan combo was too thick for my Mini-ITX so I had to go to a thinner one. But I can't see its screws size anywhere.
In this picture you can see the AIO pump installed so you can see how are the screws:
Using the AIO backplate there are big screws from the back which go through that black plastic pieces and finally to the screw with a spring.
