My mobo is running at 78c under load. thats not good huh?
Sm____
Commendable
Apr 12, 2016
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i7 2600K @ 3.40GHz 38 °C
Sandy Bridge 32nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 799MHz (9-9-9-24)
Motherboard
MSI P67A-G43 (MS-7673) (SOCKET 0) 41 °C
Graphics
Acer S232HL (1920x1080@60Hz)
2757 (1920x1080@60Hz)
2047MB NVIDIA GeForce GTX 980 Ti (EVGA) 63 °C
Storage
1863GB TOSHIBA DT01ACA200 ATA Device (SATA) 34 °C
232GB Samsung SSD 850 EVO 250GB ATA Device (SSD) 30 °C
465GB Hitachi HDS721050CLA362 ATA Device (SATA) 31 °C
Optical Drives
TSSTcorp CDDVDW SH-222AB ATA Device
specs - idle
Since this is an aged system, have you experienced the issue while you were on a platform prior to Windows 10? If not then the OS has nothing to do with it but if so then you'd need to throttle down on some settings for example the overclocks os the OS. I would like to bring another matter to light, that is, you didn't mention your chassis, the sort of cooling you have on your CPU and the case in general while you've also forgotten to add the make and model of your PSU.
Please pass them on and perhaps the culprit can be identified and apprehended :)
*Please make sure your BIOS is up to date. You can also try pointing a 120mm fan at the VRM area and see if the temps go down.
