you need a new monitor. there is no software that can fix that.CPU: Intel Xeon Inside
Motherboard:???
Ram:8.00GB(3.50 Usable)
SSD/HDD: 465.76GB
GPU: ATI FirePro V3750 (FireGL)
PSU: Stock Dell T3500 Workstation 240v supply unit
Chassis:???
OS: Windows 10 Pro
Monitor: HP 2009v
View: https://twitter.com/SSSNIPESSSNIPE/status/1610387103027990528/photo/1
= this is where i put the image
CPU: Intel Xeon InsideWelcome to the forums and a Happy New Year, newcomer!
There's only so much you can convey with the aid of text whereby you need other forms of media to get your message across/paint a picture. We could benefit from you adding images and a video of the issue of what you're facing. In the interim period, did you connect the panel to a known working donor system/display output source? Did you replace the cable to see if that might resolve the issue? You should also include the make and model of your monitor.
Better yet, please include the specs to your build like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
Motherboard:???
SSD/HDD: 465.76GB
Chassis:???
OS: Windows 10 Pro
Monitor: HP 2009v
Yeah I thought so too I wasn't sure about it beforeyou need a new monitor. there is no software that can fix that.
