A anna austin Distinguished Mar 17, 2010 1 0 18,510 Mar 17, 2010 #1 Hello, Hello My Monitor only fills about a bit more than half my screen
G Guest Guest Mar 18, 2010 #2 Make sure Windows Display Properties (see Control Panel) is set to monitor's native resolution and refresh rate. Upvote 0 Downvote
G Guest Guest May 11, 2010 #3 Try This: Right click on the desktop, select "settings" tab, and move the bar to the correct display settings for the screen. Upvote 0 Downvote
jsc Champion Jul 14, 2004 16,893 6 52,960 May 20, 2010 #4 You can also try it on another computer to make certain that there is nothing wrong with the monitor. Upvote 0 Downvote
