S skygrump Reputable Jan 15, 2015 1 0 4,510 Jan 15, 2015 #1 Monitor is an Asus VS228DE, GPU is an R9 280.
M mbarnes86 Splendid Sep 16, 2010 3,839 7 26,965 Jan 15, 2015 #2 Hi If your dvi port is dvi-I You can use a simple and cheap adapter as the dvi-I includes digital and VGA analogue signals If not you need a active converter Regards Mike Barnes Upvote 0 Downvote
S stealthsniper Reputable Feb 4, 2015 8 0 4,510 May 16, 2015 #3 Yea, They are cheap. Infact, Most GPU comes with one. Upvote 0 Downvote
G gabor.pinke Jan 10, 2019 2 0 10 Jan 10, 2019 #4 Buy something similar to this, plug the HDMI end into the GPU's HDMI slot and then plug the male VGA cable into the VGA slot. It works for me, I have a very similar setup except I'm using a GTX 1050. Upvote 0 Downvote
G gabor.pinke Jan 10, 2019 2 0 10 Jan 10, 2019 #5 https://www.amazon.com/Active-Adapter-Benfei-Converter-Gold-Plated/dp/B01KLKQN9U/ref=sr_1_1_sspa?ie=UTF8&qid=1547119615&sr=8-1-spons&keywords=hdmi+to+vga&psc=1 here is the link btw I forgot to pust it for some reason. Upvote 0 Downvote
