Question my monitor says no signal after moving my pc.
Jul 2, 2020
After i came home from a friend with my pc it just said no signal and i have never had a problem with that before i use a displayport cable and have a nvdia gtx 1060 and my monitor is a acer predator XB240H. hopefully i can get some help here and sorry if my english and gramma is bad
check all the connections, if you have same results remove each piece and put it back after that, if that doesn't work either reset the BIOS with cmos battery and the pins (before u remove the components make sure you wear rubber gloves to do not create static energy)
