Question My monitor show no signal after deep cleaning
Jul 27, 2022
Hello so today i just deep clean my pc from dust the things i only remove is my gpu and fans i didnt remove my motherboard because i have a backplate so itl be easier that way, and so 3 hours later i was done plug in all my cables etc and when i wanna turn on my monitor it says no signal and so i try chnaging hdmi cables still the same idk whats wrong because my gpu is also running but i think the problem is from gpu its either i didnt connect it right or something else
Heres are my specs :
Gpu : NVIDIA MSI GTX 1660 SUPER
MOBO : ASROCK B550 PHANTOM GAMING 4
Monitor : ASUS TUF Gaming VG249Q1A
Go thru it again, maybe you missed something or damaged something, clear CMOS first.
