My monitor shows no signal after i plug my cable to my gtx 760
Jul 22, 2018
so i played a game and then suddenly my screen turned black and i heard the plugging off sound (if you know what i mean) and i couldn't get it back to normal so i tried restarting my pc and then it showed on my screen "no signal" i tried to fix it without success, so after i plugged the cable to my other gpu (the intel graphics 4600 one) and then the pc worked again.... so now when im plugging my cable to the gpu that im mainly using (the gtx 760 one) it shows no signal, so after this try i tried to reseat my gpu and it isnt working either but the fans of the gpu are spinning... i dont know what to do to make it work i hope you guys can help me to make it work again ❤
