Question My monitor shows 'NO SIGNAL' when plugged in to GPU
Jun 4, 2022
I tried everything that I can find online to troubleshoot this problem. But sadly can't seem to find any working solution. So I took my pc to the computer store to get it fixed. They later told me that my GPU was no longer working and needed a new GPU.
My GPU fans are still spinning and LEDs are turning on. But can't get any signal through the display port or HDMI.
What could cause this problem and is there anything that I could try? Every solution is appreciated. Thank you
Lutfij
You can start by parsing the specs to your build, like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
including the age of your PSU, apart from it's make and model.
A bad quality PSU or a failing one can knock out your components.
