using google in BSOD Reputable Apr 14, 2020 194 3 4,615 Feb 22, 2021 #1 Lately, if i wake up my PC from sleep mode, the PC will turn on, but the monitor won't. i didn't do any kind of things that harms my pc like heavy duty use. any solutions to this?
Solution Ralston18 Feb 22, 2021 Update your post to include full system hardware specs and OS information. Make and model monitor? What do you do to recover the display? Have you tried reinstalling the graphics drivers and/or monitor drivers if available? Are you using a GPU or integrated GPU? If applicable and possible - try the other. Swap in another known working video cable. Try another known working monitor on your PC. Try the current monitor on another known working PC. Determine if the problem follows the monitor or stays with your PC.
Ralston18 Titan Moderator Oct 11, 2014 34,816 3,309 146,290 Feb 22, 2021 Solution #2 Update your post to include full system hardware specs and OS information. Make and model monitor? What do you do to recover the display? Have you tried reinstalling the graphics drivers and/or monitor drivers if available? Are you using a GPU or integrated GPU? If applicable and possible - try the other. Swap in another known working video cable. Try another known working monitor on your PC. Try the current monitor on another known working PC. Determine if the problem follows the monitor or stays with your PC. Upvote 0 Downvote Solution
