My motherboard becomes very hot and pc specs go low
MahmutCaliskan
Commendable
Oct 9, 2016
Hello everybody i have been with playing my pc since 2 years and there was no problem. However, one day i started getting low fps in games and i found that my 4.0 ghz cpu was running as 1.4 ghz and my 1100 mhz gpu was running as 350mhz and I couldn't find a way to fix it please help
My pc is;
Amd fx-8350 4.0 ghz stock clocked
8 gb kingston 1866mhz ram
Gtx 960 2gb gpu
650watt psu
Msi gaming 970 mobo
And there is something else when i switched pc on after bios screen the bios freezes and dot circle comes and then the windows opens its like delaying windows to open for like 10 seconds or something its just driving me crazy there was nothing like this before.
motherboard becomes very hot" what on the motherboard?
what is your cpu,gpu temps?
have you checked your voltages in the bios? are they showing ok values?
what is your cpu freq showing as in the bios? is it showing its slowed down?
are you sure you don't have a virus?
I checked my bios cpu temp are shown as 26 degrees but after pc running for 15 min it goes up to 50 degrees on idle and my cpu voltage is 0.9. However i am trying to change it to 1.4. It just doesnt change it goes back to 0.9 and my gpu looks very normal not hot at all and i also use stock fans for amd fx 8350 and 2 case fans and they are working well.
