Question My motherboard can’t connect to WiFi, please help!
Feb 23, 2023
28
I have a B660 Gaming X AX from Gigabyte and installed the WiFi, Bluetooth, and LAN drivers onto my system, but windows 11 Home says I ´Cant connect to this network.´ I tried both the antenna that comes with the Mobo and a USB WiFi adapter but neither appear to work! I’ve tried many things now and any progress in the right direction would be monumental. Thanks
WIFI a, b, g, n, ac, ax, supporting 2.4/5/6 GHz carrier frequency bands
Which frequency does your router work on ?They have to match.
Can you make wired connection ?
My house does not have Ethernet and the router is too far to connect directly, but I’ll check their frequencies to see if they match. Thank you!
